跳转到主内容
Zoomer Jurassic World Indominus Rex Back Cover Replacement
你所需要的
  1. Zoomer Jurassic World Indominus Rex Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Turn off and unplug Zoomer Jurassic World Indominus Rex from any power source before doing replacements.
    • Remove all eight (8) 9.3mm Phillips screws using Phillips #1 screwdriver.
  2. Zoomer Jurassic World Indominus Rex Back Cover Replacement: 步骤 2 中的图像 1,2 Zoomer Jurassic World Indominus Rex Back Cover Replacement: 步骤 2 中的图像 2,2
    • Pry apart the back cover of the Jurassic Indominus Rex and the rest of the body using a spudger.
    • Do not take out the back cover immediately as it it still attached to the motherboard by a wire.
  3. Zoomer Jurassic World Indominus Rex Back Cover Replacement: 步骤 3 中的图像 1,2 Zoomer Jurassic World Indominus Rex Back Cover Replacement: 步骤 3 中的图像 2,2
    • Disconnect the orange wire that connects the motherboard and the back cover.
    • Separate the back cover and the rest of the Zoomer Jurassic World Indominus Rex.
    • Gently press the tab on the side of the orange connector if you are having trouble disconnecting the wire.
结论
Anh Le
于01/20/16注册
504 声望
创作了3篇指南
团队
USF Tampa, Team 10-3, Remmell Spring 2016 USF Tampa, Team 10-3, Remmell Spring 2016 的会员
USFT-REMMELL-S16S10G3
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 18
总计 411
