跳转到主内容
Zoomer Dino Boomer Tail Tip Replacement
你所需要的
  1. Zoomer Dino Boomer Tail Tip Replacement, Tail Tip: 步骤 1 中的图像 1,2 Zoomer Dino Boomer Tail Tip Replacement, Tail Tip: 步骤 1 中的图像 2,2
    • Remove the 9.4 mm Phillips #0 screw from the bottom of the tail of Zoomer Dino Boomer.
  2. Zoomer Dino Boomer Tail Tip Replacement: 步骤 2 中的图像 1,2 Zoomer Dino Boomer Tail Tip Replacement: 步骤 2 中的图像 2,2
    • Use the spudger to pry open the two ridges on the last segment of the tail.
  3. Zoomer Dino Boomer Tail Tip Replacement: 步骤 3 中的图像 1,2 Zoomer Dino Boomer Tail Tip Replacement: 步骤 3 中的图像 2,2
    • Remove the rubber tail tip from the plastic connector.
结论
另外一个人完成了本指南。
Lauren Mannix
于08/29/15注册
398 声望
创作了3篇指南
团队
USF Tampa, Team 16-1, Wollert Fall 2015 USF Tampa, Team 16-1, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G1
3 名成员
创作了10篇指南
3条评论
Where do I buy the replacement tail? Ours broke off!
supportchris - 回复
What about the rest of the tail? The strings on mine came unattached and the whole tail came off. I am unable to successfully get the strings reattached to the end of the tail.
Bob Essl - 回复
Where can I buy a new tail tip for the green dino?
Christopher Baldwin - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 5,373
