跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide will assist the reader in replacing the tip of Zoomer Dino Boomer's tail.
配件
没有特定配件。
  1. Remove the 9.4 mm Phillips #0 screw from the bottom of the tail of Zoomer Dino Boomer. Remove the 9.4 mm Phillips #0 screw from the bottom of the tail of Zoomer Dino Boomer.
    • Remove the 9.4 mm Phillips #0 screw from the bottom of the tail of Zoomer Dino Boomer.
  2. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  3. Use the spudger to pry open the two ridges on the last segment of the tail. Use the spudger to pry open the two ridges on the last segment of the tail.
    • Use the spudger to pry open the two ridges on the last segment of the tail.
  4. Remove the rubber tail tip from the plastic connector. Remove the rubber tail tip from the plastic connector.
    • Remove the rubber tail tip from the plastic connector.
结论
另外一个人完成了本指南。
Lauren Mannix
于2015年08月29日注册
392 信誉积分
创作了3篇指南
团队
USF Tampa, Team 16-1, Wollert Fall 2015 USF Tampa, Team 16-1, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G1
3 名成员
创作了5篇指南
Where do I buy the replacement tail? Ours broke off!
supportchris - 回复
What about the rest of the tail? The strings on mine came unattached and the whole tail came off. I am unable to successfully get the strings reattached to the end of the tail.
Bob Essl - 回复
Where can I buy a new tail tip for the green dino?
Christopher Baldwin - 回复
添加评论
浏览统计数据:
过去的24小时: 5
过去的7天: 5
过去的30天: 25
总计 4,662
