当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Use a soldering iron to remove the wires from the sensor chip by melting the metal joints on the chip.
Use the tweezers to remove the wires as you are soldering them.
Do not touch any parts of Zoomer Dino Boomer or yourself when using the soldering iron. The soldering iron will be very hot.
When reassembling, extra solder may be required to reconnect the wires with the circuit board.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
