本指南有最近更改,您可查看未经巡查的最新版本。
简介
Before removing and replacing the sensor of Zoomer Dino Boomer, check the Troubleshooting Page to make sure the issue with gesture mode cannot be fixed without removing the sensor.
你所需要的
Unscrew the two 7.5 mm Phillips #0 screws at the base of the neck.
Remove the two 7.2 mm Phillips #0 screws above these at the base of the mouth.
即将完成!
结论
