跳转到主内容
Zoomer Dino Boomer Main Circuit Board Replacement
你所需要的
  1. Zoomer Dino Boomer Main Circuit Board Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Power off Zoomer Dino Boomer before disassembly.
    • Remove the eight 9.3mm Phillips #1 screws.
  2. Zoomer Dino Boomer Main Circuit Board Replacement: 步骤 2 中的图像 1,2 Zoomer Dino Boomer Main Circuit Board Replacement: 步骤 2 中的图像 2,2
    • Turn dinosaur over and hold upright.
    • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
    • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
  3. Zoomer Dino Boomer Main Circuit Board Replacement: 步骤 3 中的图像 1,3 Zoomer Dino Boomer Main Circuit Board Replacement: 步骤 3 中的图像 2,3 Zoomer Dino Boomer Main Circuit Board Replacement: 步骤 3 中的图像 3,3
    • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
    • Remove back cover.
    • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
    • Do not damage the wires or circuit board.
  4. Zoomer Dino Boomer Main Circuit Board Replacement, Main Circuit Board: 步骤 4 中的图像 1,3 Zoomer Dino Boomer Main Circuit Board Replacement, Main Circuit Board: 步骤 4 中的图像 2,3 Zoomer Dino Boomer Main Circuit Board Replacement, Main Circuit Board: 步骤 4 中的图像 3,3
    • Use tweezers to remove all of the colored wire connectors from their sockets on the circuit board.
    Where can i find the circuit board to purchase?
    Scott G - 回复
  5. Zoomer Dino Boomer Main Circuit Board Replacement: 步骤 5 中的图像 1,2 Zoomer Dino Boomer Main Circuit Board Replacement: 步骤 5 中的图像 2,2
    • Remove legs.
  6. Zoomer Dino Boomer Main Circuit Board Replacement: 步骤 6 中的图像 1,1
    • Remove the three 7.2 mm Phillips #0 screws connecting the main circuit board to the body of Zoomer Dino Boomer.
  7. Zoomer Dino Boomer Main Circuit Board Replacement: 步骤 7 中的图像 1,3 Zoomer Dino Boomer Main Circuit Board Replacement: 步骤 7 中的图像 2,3 Zoomer Dino Boomer Main Circuit Board Replacement: 步骤 7 中的图像 3,3
    • Use soldering iron and tweezers to disconnect main circuit board from the black and red wires.
    • Check out iFixit's soldering techniques guide to learn more about soldering and desoldering connections.
    • Remove main circuit board from Zoomer Dino Boomer
    The problem is buying mainboard, Could you write contact informations of the sellers?
    Mehmet Yener - 回复
    Would like to know what is wrong with the circuit board. Is it a bad capacitor, computer chip or other electronic component? Or is it a cracked circuit board? If it is a cracked circuit board, they can be fixed if you solder a wire across the brake in the printed circuit. I save 1 or 2 bad cables from computer accessories and some USB cables for the small thin wire for some of the small stuff. That repair can be difficult if it is a small packed board. But I've repaired many cracked circuit boards from dropped items by soldering a wire across the brake. If it is a component like a capacitor, they can be de soldered and replaced. I had a capacitor go bad in the ECM of my truck, took 30 minutes to replace it. But it took a whole day to R&R the ECM.
    But these are great instructions to repair this toy!
    EIBBOR2654 - 回复
结论
5等其他人完成本指南。
团队
USF Tampa, Team 16-1, Wollert Fall 2015 USF Tampa, Team 16-1, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G1
3 名成员
创作了10篇指南
3条评论
can anyone tell me where to get a replacement motherboard?
alan.scott - 回复
Nah cuz my dino doesn't show any life support at all just the controller and Idek what's the issue. If this is the way to solve it be so for real tell me where to get that new circuit.
Nightmare_Requiem - 回复
The batteries location?
Tony Beatenbo - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 4,429
