跳转到主内容
Fix Your Stuff
Right to Repair
Parts & Tools
简介
This guide shows how to safely separate the main circuit board from the remainder of Zoomer Dino Boomer so that it can be replaced without damage to the electrical system.
精选文档
  1. Power off Zoomer Dino Boomer before disassembly.
    • Power off Zoomer Dino Boomer before disassembly.
    • Remove the eight 9.3mm Phillips #1 screws.
  2. Turn dinosaur over and hold upright. Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
    • Turn dinosaur over and hold upright.
    • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
    • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
  3. Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers. Remove back cover. If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
    • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
    • Remove back cover.
    • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
    • Do not damage the wires or circuit board.
  4. Use tweezers to remove all of the colored wire connectors from their sockets on the circuit board. Use tweezers to remove all of the colored wire connectors from their sockets on the circuit board. Use tweezers to remove all of the colored wire connectors from their sockets on the circuit board.
    • Use tweezers to remove all of the colored wire connectors from their sockets on the circuit board.
  5. Remove legs. Remove legs.
    • Remove legs.
  6. Remove the  three 7.2 mm Phillips #0 screws connecting the main circuit board to the body of Zoomer Dino Boomer.
    • Remove the three 7.2 mm Phillips #0 screws connecting the main circuit board to the body of Zoomer Dino Boomer.
  7. Use soldering iron and tweezers  to disconnect main circuit board from the black and red wires. Check out iFixit's soldering techniques guide to learn more about soldering and desoldering connections. Remove main circuit board from Zoomer Dino Boomer
    • Use soldering iron and tweezers to disconnect main circuit board from the black and red wires.
    • Check out iFixit's soldering techniques guide to learn more about soldering and desoldering connections.
    • Remove main circuit board from Zoomer Dino Boomer
结论
5等其他人完成本指南。
附加文件
Desiree DesJardins
于2015年09月02日注册
442 信誉积分
创作了2篇指南
团队
USF Tampa, Team 16-1, Wollert Fall 2015 USF Tampa, Team 16-1, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G1
3 名成员
创作了5篇指南
can anyone tell me where to get a replacement motherboard?
alan.scott - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 6
过去的30天: 48
总计 3,061
