跳转到主内容
Zoom Q3HD Handy Video Recorder Lens Cleaning
你所需要的
  1. Zoom Q3HD Handy Video Recorder Lens Cleaning, Zoom Q3HD Handy Video Recorder Lens Cleaning: 步骤 1 中的图像 1,1
    • Remove the two screws from the bottom of the device.
    • Make sure to put your screws in a safe place.
  2. Zoom Q3HD Handy Video Recorder Lens Cleaning: 步骤 2 中的图像 1,1
    • Flip the device over and remove the four screws bordering the grate of the device.
  3. Zoom Q3HD Handy Video Recorder Lens Cleaning: 步骤 3 中的图像 1,1
    • On the front of the device, slide the battery compartment cover off by pushing inward and sliding downward.
  4. Zoom Q3HD Handy Video Recorder Lens Cleaning: 步骤 4 中的图像 1,1
    • Remove the two screws from the lip of the battery compartment.
  5. Zoom Q3HD Handy Video Recorder Lens Cleaning: 步骤 5 中的图像 1,1
    • Remove the final screw from the bed of the battery compartment.
  6. Zoom Q3HD Handy Video Recorder Lens Cleaning: 步骤 6 中的图像 1,1
    • WARNING: Pieces may become loose when you separate the device in half!
    • Run the pry tool along the edges of the device to begin separating the device in two halves.
  7. Zoom Q3HD Handy Video Recorder Lens Cleaning: 步骤 7 中的图像 1,2 Zoom Q3HD Handy Video Recorder Lens Cleaning: 步骤 7 中的图像 2,2
    • REMINDER: Pieces may become loose when you separate the device in half!
    • Apply upward pressure to fully separate the device into two halves.
  8. Zoom Q3HD Handy Video Recorder Lens Cleaning: 步骤 8 中的图像 1,1
    • WARNING: If you’re not careful with keeping the screen close to the board, you will rip off the ribbon attaching the screen to the circuit board.
    • Lift display screen keeping the top half close to the board.
  9. Zoom Q3HD Handy Video Recorder Lens Cleaning: 步骤 9 中的图像 1,1
    • Gently flip the black clip up attaching the ribbon of the screen to the circuit board.
  10. Zoom Q3HD Handy Video Recorder Lens Cleaning: 步骤 10 中的图像 1,1
    • Gently slide the ribbon from the circuit board, removing the screen.
结论
2等其他人完成本指南。
Grace Bently
于10/13/14注册
4 声望
撰写一个指南
团队
Ohio State, Team 1-1, Mccook Fall 2014 Ohio State, Team 1-1, Mccook Fall 2014 的会员
OSU-MCCOOK-F14S1G1
4 名成员
创作了1篇指南
3条评论
My zoom q3HD only have the red light turned on when powering up. No display at all. What is happening? How can I claim warranty? I didn't use the device more than a year. Help me
stancalvin - 回复
This is not comlete, leaves you half way through, would be great if you could finish this, thank you.
smoldas.l - 回复
Yes it would be good to see it finished. I am half way through taking mine apart to clean the lens amd i don't know if i should proceed or not. Its the 2nd time the lens has fogged up. My 2nd q3hd.
steven kemsley - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 1,986
