跳转到主内容
  1. Turn the device over with its display down.
    • Turn the device over with its display down.
  2. Remove the battery cover, pressing down on the tabs and sliding.
    • Remove the battery cover, pressing down on the tabs and sliding.
  3. Unscrew the two (2)  #00, 10 mm screws located below the mic on the back cover.
    • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover.
  4. iPhone 电池维修工具包
    只要 $29.99
    Buy Now
    iPhone 电池维修工具包
    只要 $29.99
    Buy Now
  5. Carefully pry up the top end of the back cover using one finger.
    • Carefully pry up the top end of the back cover using one finger.
  6. Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
    • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
  7. De-solder the white and black speaker wires from their soldering points.
    • De-solder the white and black speaker wires from their soldering points.
    • Speaker soldering points are located on the thin section of the blue circuit board, and are marked with “SP+” and “SP-”.
    • Keep in mind which color wire was connected at which terminal.
  8. Remove the damaged speaker from its place at the very bottom of the case, just below the battery input.
    • Remove the damaged speaker from its place at the very bottom of the case, just below the battery input.
    • You will have to break the glue holding the speaker in place before removing it.
  9. Replace the damaged speaker and re-solder to the original solder points.
    • Replace the damaged speaker and re-solder to the original solder points.
    • Ensure that the negative wire is soldered to the “SP-” while the positive wire is soldered to the “SP+” point.
结论
Alex
于2013年10月28日注册
758 信誉积分
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 7
总计 1,070
