跳转到主内容
加入维修社区 - 创建账户
Zoom H1 Handy Recorder Battery Terminal Replacement
你所需要的
  1. Zoom H1 Handy Recorder Battery Terminal Replacement, Battery Terminal: 步骤 1 中的图像 1,1
    • Place the device so the display is down.
    询问修复机器人
  2. Zoom H1 Handy Recorder Battery Terminal Replacement: 步骤 2 中的图像 1,1
    • Remove the battery cover, pressing down on the tabs and sliding.
    询问修复机器人
  3. Zoom H1 Handy Recorder Battery Terminal Replacement: 步骤 3 中的图像 1,1
    • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover
    询问修复机器人
  4. Zoom H1 Handy Recorder Battery Terminal Replacement: 步骤 4 中的图像 1,1
    • Carefully pry up the top end of the back cover using one finger
  5. Zoom H1 Handy Recorder Battery Terminal Replacement: 步骤 5 中的图像 1,1
    • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
    询问修复机器人
  6. Zoom H1 Handy Recorder Battery Terminal Replacement: 步骤 6 中的图像 1,1
    • De-solder at terminal point one.
    询问修复机器人
  7. Zoom H1 Handy Recorder Battery Terminal Replacement: 步骤 7 中的图像 1,1
    • De-solder at the second terminal point.
    询问修复机器人
  8. Zoom H1 Handy Recorder Battery Terminal Replacement: 步骤 8 中的图像 1,2 Zoom H1 Handy Recorder Battery Terminal Replacement: 步骤 8 中的图像 2,2
    • Remove the faulty terminals
    询问修复机器人
  9. Zoom H1 Handy Recorder Battery Terminal Replacement: 步骤 9 中的图像 1,1
    • Place new lead in at point one and re-solder at the point.
    询问修复机器人
  10. Zoom H1 Handy Recorder Battery Terminal Replacement: 步骤 10 中的图像 1,1
    • Place second lead at point 2 and re-solder.
    询问修复机器人
结论
To Re-construct device, perform these steps in reverse order.
Alex
于10/28/13注册
809 声望
创作了5篇指南
7指南评论
Caution is needed with step 5. My backside broke off using a spudger to attempt to remove.
Joe Vaughan - 回复 分享
Mine has third screw under the serial-number sticker.
halluciana - 回复 分享
Can anyone advise where to find replacement terminals? My zoom h1 has bad corrosion of its battery terminals and I would like to follow this guide to fix them! Thanks!
Dylan St John - 回复 分享
My zoom h1 is just dead with no reason , can i fix my zoom h1 with this guide ??
Jas Jes! - 回复 分享
Same problem, without any reason it is dead
eevilcute - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 93
总计 7,338
