跳转到主内容
Zoll Impact Uni-Vent 731 Power Knob Kit Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement, Power Knob Kit: 步骤 1 中的图像 1,1
    • Loosen but do not remove the(4) 8-32 X 3 screws on the outer air intake
    • Pg. 29
  2. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: 步骤 2 中的图像 1,1
    • Loosen and remove the (2) 10-32 Keps nuts and the (4) 6-32 X 2 screws. Remove the back case by lifting from the ventilator
    • Pg. 29
  3. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: 步骤 3 中的图像 1,1
    • Remove the (2) 4-40 X ¼ screws on the Dovetail Mounting Bracket and disconnect the ribbon cable on the PIM PCB by simultaneously applying pressure on the two locking “ears”
    • Pg. 29
  4. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: 步骤 4 中的图像 1,1
    • Flip the ventilator over and remove the front case assembly by lifting it straight up away from the ventilator module
    • Pg. 29
  5. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: 步骤 5 中的图像 1,1
    • Remove the bezel by loosening and removing the (7) 4-40 X ¼ screws that hold the bezel to the front case
    • Pg. 29
  6. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: 步骤 6 中的图像 1,1
    • On the membrane panel assembly, loosen the 6-32 X ¼ set screw using a 1/16 Ball Hex Driver (located in the power knob) and lift the damaged knob from the membrane panel
    • Pg. 30
  7. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: 步骤 7 中的图像 1,1
    • Place the replacement knob on the membrane panel switch -align with flat on switch –insert the included 6-32 X ¼ set screw and tighten
    • Pg. 30
  8. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: 步骤 8 中的图像 1,1
    • Install the new bezel by tightening the included (7) 4-40 X ¼ screws
    • Pg. 30
  9. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: 步骤 9 中的图像 1,1
    • Place the front case assembly over the vent module and tighten the (2) 4-40 X ¼ screws unto the dovetail mounting bracket. Reconnect the ribbon cable unto the PIM PCB. Make sure the two locking “ears” lock into position
    • Pg. 30
  10. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: 步骤 10 中的图像 1,1
    • Attach the back case to the vent module and align cover with handle, air intake housing and dovetail mounting studs. Insert and tighten the included (2) 10-32 Keps nuts and the (4) 6-32 X 2” screws
    • Pg. 30
  11. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: 步骤 11 中的图像 1,1
    • Tighten the (4) 8-32 X 3 screws on the outer air intake
    • Pg. 30
  12. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: 步骤 12 中的图像 1,1
    • Perform HiPot Testing then perform Calibration and Functional Test using the RCS
    • Pg. 30
结论
Emily
于05/04/20注册
206 声望
撰写一个指南
团队
Cal Poly, Team S1-G5, Zimmerman Spring 2020 Cal Poly, Team S1-G5, Zimmerman Spring 2020 的会员
CPSU-ZIMMERMAN-S20S1G5
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 157
