跳转到主内容
Zoiinet AK1 Smart Switch Battery Replacement
你所需要的
  1. Zoiinet AK1 Smart Switch Battery Replacement, Dislodge Mount from Wall: 步骤 1 中的图像 1,1
    • Dislodge the switch mounting plate from the wall (if applicable -- you may have adhesive on the back or basic screws)
  2. Zoiinet AK1 Smart Switch Battery Replacement, Eject the Rocker Switch: 步骤 2 中的图像 1,1
    • Gently press on the rocker switch from the back of the plate, it should easily pop out.
  3. Zoiinet AK1 Smart Switch Battery Replacement, Dislodge Switch Plate from Hinges: 步骤 3 中的图像 1,2 Zoiinet AK1 Smart Switch Battery Replacement, Dislodge Switch Plate from Hinges: 步骤 3 中的图像 2,2
    • Using either an iFixit pick or fingernail gently pull apart from the middle of the switch on one side. The switch face should pop off its hinge.
  4. Zoiinet AK1 Smart Switch Battery Replacement, Dislodge Inner Plate: 步骤 4 中的图像 1,2 Zoiinet AK1 Smart Switch Battery Replacement, Dislodge Inner Plate: 步骤 4 中的图像 2,2
    • There is an inner plastic plate held in place by 8x plastic tabs (2 on each side). Inset the iFixit pick into each pair, gently wedging/rotating in until the tabs are blocked for 2 or 3 sides. The inner plate should come loose
    • Note: There is an up arrow indicating the "on" portion of the switch. This matches an arrow on the back of the rocker switch from the previous step
  5. Zoiinet AK1 Smart Switch Battery Replacement, Remove Membrane & Circuit Board: 步骤 5 中的图像 1,1
    • The silicon membrane sits loosely atop the circuit board and the CR2032 battery within. Lift both out.
  6. Zoiinet AK1 Smart Switch Battery Replacement, Replace the Battery: 步骤 6 中的图像 1,2 Zoiinet AK1 Smart Switch Battery Replacement, Replace the Battery: 步骤 6 中的图像 2,2
    • Use a small screwdriver, pen, or iFixit opener tool and press from the underside of the battery compartment to slide the old battery up and out.
    • Insert a new CR2032 battery from the top, the positive (+) side should face you
  7. Zoiinet AK1 Smart Switch Battery Replacement, Reassemble + Test: 步骤 7 中的图像 1,1
    • Restore the circuit board and membrane to the inner housing. If all is functional, the On button at the top (up arrow) should flash a green LED when the circuit connects.
结论
You're done! Congratulations!
Repair4Lyfe
于08/23/25注册
145 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 45
