跳转到主内容
Zippo Lighter Felt Pad and Cotton Replacement
你所需要的
  1. Zippo Lighter Felt Pad and Cotton Replacement, Felt Pad and Cotton: 步骤 1 中的图像 1,3 Zippo Lighter Felt Pad and Cotton Replacement, Felt Pad and Cotton: 步骤 1 中的图像 2,3 Zippo Lighter Felt Pad and Cotton Replacement, Felt Pad and Cotton: 步骤 1 中的图像 3,3
    • Open the lid of the lighter.
    • Hold the bottom of the lighter’s case and pull out the metal container.
    • Set the case aside for now.
  2. Zippo Lighter Felt Pad and Cotton Replacement: 步骤 2 中的图像 1,2 Zippo Lighter Felt Pad and Cotton Replacement: 步骤 2 中的图像 2,2
    • Turn the metal container upside down with the bottom facing you.
    • You should see a piece of white felt with the words “Lift to fill.”
  3. Zippo Lighter Felt Pad and Cotton Replacement: 步骤 3 中的图像 1,2 Zippo Lighter Felt Pad and Cotton Replacement: 步骤 3 中的图像 2,2
    • Loosen the screw with a flathead screwdriver.
    • There is a spring behind the screw, so make sure you are unscrewing slowly and gently.
    • Remove the screw with the spring and the flint attached to it.
  4. Zippo Lighter Felt Pad and Cotton Replacement: 步骤 4 中的图像 1,2 Zippo Lighter Felt Pad and Cotton Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Lift the felt pad up and out of the metal container using a pair of tweezers.
  5. Zippo Lighter Felt Pad and Cotton Replacement: 步骤 5 中的图像 1,2 Zippo Lighter Felt Pad and Cotton Replacement: 步骤 5 中的图像 2,2
    • Use a pair of tweezers to remove the old cotton from the inside.
    • When adding new cotton, it should fully cover the inside of the metal canister.
    • Throw the old felt and cotton in the garbage.
  6. Zippo Lighter Felt Pad and Cotton Replacement: 步骤 6 中的图像 1,3 Zippo Lighter Felt Pad and Cotton Replacement: 步骤 6 中的图像 2,3 Zippo Lighter Felt Pad and Cotton Replacement: 步骤 6 中的图像 3,3
    • Use a pair of tweezers to push each cotton piece on top of the wick inside the metal container. Make sure the cotton pieces cover all the sides.
  7. Zippo Lighter Felt Pad and Cotton Replacement: 步骤 7 中的图像 1,1
    • Use a pair of tweezers to place the new felt pad on top of the cotton pieces.
  8. Zippo Lighter Felt Pad and Cotton Replacement: 步骤 8 中的图像 1,2 Zippo Lighter Felt Pad and Cotton Replacement: 步骤 8 中的图像 2,2
    • Replace the flint and screw it back into place using a flathead screwdriver.
  9. Zippo Lighter Felt Pad and Cotton Replacement: 步骤 9 中的图像 1,2 Zippo Lighter Felt Pad and Cotton Replacement: 步骤 9 中的图像 2,2
    • Refuel your lighter, put the metal container back inside the case, and test out the lighter.
    • Only use the lighter when it is secured inside the case.
终点
另外一个人完成了本指南。
Dara
于10/01/21注册
193 声望
撰写一个指南
团队
York University, Team G-35, O'Regan Fall 2021 York University, Team G-35, O'Regan Fall 2021 的会员
YORK-O'REGAN-F21SGG35
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 56
过去 30 天: 209
总计 9,070
