跳转到主内容
Zink Polaroid ZIP Wireless Mobile Photo Mini Printer Battery Replacement
你所需要的
  1. Zink Polaroid ZIP Wireless Mobile Photo Mini Printer Battery Replacement, Open printer: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Pro Tech Toolkit
    $59.96
    • Open the paper trail
    • Get your screw driver with a Philips bit (from your Pro Tech Toolkit for instance) and unscrew the four screws at each corner
    • Unclip lid delicately with the help of a guitar pick or with the Jimmy tool.
  2. Zink Polaroid ZIP Wireless Mobile Photo Mini Printer Battery Replacement, Unplug battery: 步骤 2 中的图像 1,1
    • Unplug the battery pack and remove it
    • You can also see the internals of this device directly on the FCC ID website.
  3. Zink Polaroid ZIP Wireless Mobile Photo Mini Printer Battery Replacement, Remove foam padding: 步骤 3 中的图像 1,3 Zink Polaroid ZIP Wireless Mobile Photo Mini Printer Battery Replacement, Remove foam padding: 步骤 3 中的图像 2,3 Zink Polaroid ZIP Wireless Mobile Photo Mini Printer Battery Replacement, Remove foam padding: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    iOpener
    $24.99
    • Remove the foam padding from the battery
    • Optional: use a warming element like the bed of your 3D printer or iFixit iOpener
    • Place the foam on your new battery
  4. Zink Polaroid ZIP Wireless Mobile Photo Mini Printer Battery Replacement, Make sure connector's wires are matching: 步骤 4 中的图像 1,1
    • Make sure the connector of your new battery pack is matching the one you remove
    • If it's not matching, for each wrong pin:
    • Push down pin in the cover part of the connector
    • Pull on the pin to extract it from connector
    • Place it back in right spot
  5. Zink Polaroid ZIP Wireless Mobile Photo Mini Printer Battery Replacement, Plug new battery pack: 步骤 5 中的图像 1,1
    • Place and plug new battery pack
    • Plug device with USB mini cable and test device is charging
    • If blinking red, unplug immediately and verify polarity of your battery pack
    • If the LED indicator stays red-still for more than 60 seconds, you replaced the battery successfully! 🎉
    • Clip lid back and put back the screws
    • Charge battery fully, until LED turns green, before using.
结论
It was really satisfying to be able to avoid throwing away the whole product, and only replace the battery pack. So happy to be able to use this mini printer again!
To recycle the battery, call +1 800-822-8837 or go to call2recycle.org.
2等其他人完成本指南。
Ronan
于04/01/23注册
196 声望
撰写一个指南
1指南评论
Can you show where to unclip the lid to get to the battery?
Patricia Slice - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 34
过去 30 天: 133
总计 2,687
