跳转到主内容
Zenithink ZTPAD ZT280 C91 Screen Replacement
你所需要的
  1. Zenithink ZTPAD ZT280 C91 Screen Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the two screws on the bottom using a Phillips #00 screwdriver.
    • For differentiation purposes, these screws are 4mm long.
  2. Zenithink ZTPAD ZT280 C91 Screen Replacement: 步骤 2 中的图像 1,3 Zenithink ZTPAD ZT280 C91 Screen Replacement: 步骤 2 中的图像 2,3 Zenithink ZTPAD ZT280 C91 Screen Replacement: 步骤 2 中的图像 3,3
    • Using a spudger, start prying the case apart by working around the edge slowly.
    • Be careful not to damage any of the latches that hold the back panel in place, especially if you are using a metal spudger.
    • While prying, be careful to not lose the power and volume buttons; the case is the only thing holding them in place so they will easily come out once the panel has been removed
    • Be careful to not damage the speaker cables, they will still be connecting both panels.
  3. Zenithink ZTPAD ZT280 C91 Screen Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Peel back the touch interface chip (which is on the top right of the motherboard, covered in yellow tape.)
  4. Zenithink ZTPAD ZT280 C91 Screen Replacement: 步骤 4 中的图像 1,1
    • Flip up the small gate and unplug the ribbon cable shown.
  5. Zenithink ZTPAD ZT280 C91 Screen Replacement: 步骤 5 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the screws highlighted with the orange rings as shown in the picture.
    • For differentiation purposes, these screws are 3.5mm long.
  6. Zenithink ZTPAD ZT280 C91 Screen Replacement: 步骤 6 中的图像 1,1
    • Slide back the plastic latch for the main display cable.
    • Carefully unplug the cable with tweezers.
  7. Zenithink ZTPAD ZT280 C91 Screen Replacement: 步骤 7 中的图像 1,2 Zenithink ZTPAD ZT280 C91 Screen Replacement: 步骤 7 中的图像 2,2
    • Slide back the plastic latch for the camera cable.
  8. Zenithink ZTPAD ZT280 C91 Screen Replacement: 步骤 8 中的图像 1,1
    • Peel back the reflective tape.
  9. Zenithink ZTPAD ZT280 C91 Screen Replacement: 步骤 9 中的图像 1,2 Zenithink ZTPAD ZT280 C91 Screen Replacement: 步骤 9 中的图像 2,2
    • Lift up the motherboard assembly, starting by lifting up the top.
    • Be careful not to damage any of the ports on the underside of the tablet.
    • The camera cable will slide through a small notch and end up underneath the board.
  10. Zenithink ZTPAD ZT280 C91 Screen Replacement, Front Panel: 步骤 10 中的图像 1,1
    • Remove the four highlighted screws using a Phillips #1 screwdriver.
    • For differentiation purposes, these screws are 4mm long and have a larger head than the rest of the screws.
  11. Zenithink ZTPAD ZT280 C91 Screen Replacement: 步骤 11 中的图像 1,1
    • Starting from the top, slowly lift everything up out of the front panel.
    • Remove the front panel off of the device.
    • Be careful not to damage the ports along the bottom.
  12. Zenithink ZTPAD ZT280 C91 Screen Replacement, Screen: 步骤 12 中的图像 1,1
    • Peel back the adhesive from one of the top corners.
    • We recommend to use only your hands to avoid damage to the battery.
  13. Zenithink ZTPAD ZT280 C91 Screen Replacement: 步骤 13 中的图像 1,1
    • While you're peeling the adhesive back, be careful because the display is connected by a cable on the right.
  14. Zenithink ZTPAD ZT280 C91 Screen Replacement: 步骤 14 中的图像 1,1
    • Using tweezers, slide back the latch and unplug the ribbon cable.
    • Remove the display from the device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 182
