跳转到主内容
Zenithink ZTPAD ZT280 C91 Back Panel Replacement
你所需要的
  1. Zenithink ZTPAD ZT280 C91 Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the two screws on the bottom using a Phillips #00 screwdriver.
    • For differentiation purposes, these screws are 4mm long.
  2. Zenithink ZTPAD ZT280 C91 Back Panel Replacement: 步骤 2 中的图像 1,3 Zenithink ZTPAD ZT280 C91 Back Panel Replacement: 步骤 2 中的图像 2,3 Zenithink ZTPAD ZT280 C91 Back Panel Replacement: 步骤 2 中的图像 3,3
    • Using a spudger, start prying the case apart by working around the edge slowly.
    • Be careful not to damage any of the latches that hold the back panel in place, especially if you are using a metal spudger.
    • While prying, be careful to not lose the power and volume buttons; the case is the only thing holding them in place so they will easily come out once the panel has been removed
    • Be careful to not damage the speaker cables, they will still be connecting both panels.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 159
