跳转到主内容
Zeki TBQG884B Rear Case Replacement
你所需要的
  1. Zeki TBQG884B Rear Case Replacement, Rear Case: 步骤 1 中的图像 1,2 Zeki TBQG884B Rear Case Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
  2. Zeki TBQG884B Rear Case Replacement: 步骤 2 中的图像 1,1
    • Place the tablet down so that the screen is facing away from you.
    • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
    • Gently work your way around the perimeter of the tablet's edge.
  3. Zeki TBQG884B Rear Case Replacement: 步骤 3 中的图像 1,2 Zeki TBQG884B Rear Case Replacement: 步骤 3 中的图像 2,2
    • Remove the back cover
    • Remove any tape on the speaker and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
结论
David Wyman
于09/16/15注册
343 声望
创作了3篇指南
团队
IUPUI, Team 1-3, Harley Fall 2015 IUPUI, Team 1-3, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S1G3
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 14
总计 376
