跳转到主内容
Zeki TBQG884B Camera Replacement
你所需要的
  1. Zeki TBQG884B Camera Replacement, Rear Case: 步骤 1 中的图像 1,2 Zeki TBQG884B Camera Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
  2. Zeki TBQG884B Camera Replacement: 步骤 2 中的图像 1,1
    • Place the tablet down so that the screen is facing away from you.
    • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
    • Gently work your way around the perimeter of the tablet's edge.
  3. Zeki TBQG884B Camera Replacement: 步骤 3 中的图像 1,2 Zeki TBQG884B Camera Replacement: 步骤 3 中的图像 2,2
    • Remove the back cover
    • Remove any tape on the speaker and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
  4. Zeki TBQG884B Camera Replacement, Camera: 步骤 4 中的图像 1,2 Zeki TBQG884B Camera Replacement, Camera: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Open the ZIF connector, the black lock part over the wire ribbon in the motherboard, and remove the wire ribbon that connects the motherboard and the camera.
    • The camera is located on the top left, above the motherboard.
    • The camera is usually covered with tape or material. Peel material/tape off with tweezers for safety.
结论
3等其他人完成本指南。
Natalie Holm
于09/16/15注册
146 声望
撰写一个指南
团队
IUPUI, Team 1-3, Harley Fall 2015 IUPUI, Team 1-3, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S1G3
5 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 313
