跳转到主内容
Zeki Droid Tablet Front Screen Replacement
你所需要的
  1. Zeki Droid Tablet Front Screen Replacement, Back Casing: 步骤 1 中的图像 1,1
    • Remove the back casing by slowly popping each tab out with a plastic opening tool.
  2. Zeki Droid Tablet Front Screen Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the tapes one by one from the connecting wires with tweezers.
  3. Zeki Droid Tablet Front Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the black clips from both sides of the casing with a plastic opening tool.
    • The clips should pop off separate from the speakers.
  4. Zeki Droid Tablet Front Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the speakers from the back casing.
    • Do not tug on the speakers because they are connected to fragile wires.
  5. Zeki Droid Tablet Front Screen Replacement: 步骤 5 中的图像 1,1
    • Pull the speakers away from the back casing carefullly.
  6. Zeki Droid Tablet Front Screen Replacement, Front Screen: 步骤 6 中的图像 1,1
    • Detach the motherboard from the framing by removing the four screws using a Phillips #000 screwdriver.
  7. Zeki Droid Tablet Front Screen Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    • Lift the camera and flash components from their fittings using tweezers.
  8. Zeki Droid Tablet Front Screen Replacement: 步骤 8 中的图像 1,1
    • Lift the metal framing to reach the components at the front of the device.
    • Do not pull the framing completely off. There is a ZIF connecter holding it in place.
  9. Zeki Droid Tablet Front Screen Replacement: 步骤 9 中的图像 1,2 Zeki Droid Tablet Front Screen Replacement: 步骤 9 中的图像 2,2
    • Push the screen forward to remove.
结论
Kyla
于03/11/15注册
156 声望
创作了2篇指南
团队
Colorado Springs, Team 2-6, Panko Spring 2015 Colorado Springs, Team 2-6, Panko Spring 2015 的会员
UCCS-PANKO-S15S2G6
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 405
