跳转到主内容
Zeepad 7DRK Speaker Replacement
你所需要的
  1. Zeepad 7DRK Speaker Replacement, Speaker: 步骤 1 中的图像 1,2 Zeepad 7DRK Speaker Replacement, Speaker: 步骤 1 中的图像 2,2
    • Begin by popping off the plastic yellow device casing with the soft tip prying tool.
    • Start by using the wedging the tip of the tool in and working your way around the device to make things easier.
  2. Zeepad 7DRK Speaker Replacement: 步骤 2 中的图像 1,2 Zeepad 7DRK Speaker Replacement: 步骤 2 中的图像 2,2
    • Once the device is opened, the speaker should fall out of its position.
    • Follow the red and black wires attached to the speaker to find the location of connection.
  3. Zeepad 7DRK Speaker Replacement: 步骤 3 中的图像 1,1
    • The red and black wires are attached by a solder, in order to be replaced this connection must be broken.
    • Once the wires are disconnected, the speaker will be successfully removed and ready for replacement.
结论
Alexandra Souza
于10/20/16注册
222 声望
创作了2篇指南
团队
UMass Dartmouth, Team 6-8, Martin Fall 2016 UMass Dartmouth, Team 6-8, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S6G8
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 102
