跳转到主内容
Zeepad 7DRK Power and Volume Button Replacement
你所需要的
  1. Zeepad 7DRK Power and Volume Button  Replacement, Power and Volume Buttons: 步骤 1 中的图像 1,1
    • First find the power and volume buttons so that you are familiar with their location.
    • The smaller button is the power button and the larger button is the volume button.
  2. Zeepad 7DRK Power and Volume Button  Replacement: 步骤 2 中的图像 1,2 Zeepad 7DRK Power and Volume Button  Replacement: 步骤 2 中的图像 2,2
    • To open the tablet, use one of the soft-tip prying tools.
    • It is easiest to start by using the corner of the tool first and sliding the rest in. Then carefully move the tool around the edges of the tablet until it separates.
  3. Zeepad 7DRK Power and Volume Button  Replacement: 步骤 3 中的图像 1,1
    • Be careful of how you open the tablet, as the button will want to fall out. Try opening it flat on its back to avoid this problem.
    • This is what the tablet looks like when pried apart.
  4. Zeepad 7DRK Power and Volume Button  Replacement: 步骤 4 中的图像 1,2 Zeepad 7DRK Power and Volume Button  Replacement: 步骤 4 中的图像 2,2
    • In the first picture you will see the power button. Notice the small plastic ring that sticks out the side, this is so the piece can be positioned easily when you put it back together.
    • In the second picture, the volume control button is shown. Again notice the small locator rings.
  5. Zeepad 7DRK Power and Volume Button  Replacement: 步骤 5 中的图像 1,2 Zeepad 7DRK Power and Volume Button  Replacement: 步骤 5 中的图像 2,2
    • Now remove the old or broken buttons, and replace them.
结论
另外一个人完成了本指南。
Trevor Taylor
于10/20/16注册
234 声望
创作了2篇指南
团队
UMass Dartmouth, Team 6-8, Martin Fall 2016 UMass Dartmouth, Team 6-8, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S6G8
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 442
