跳转到主内容
加入维修社区 - 创建账户
Zeepad 7DRK Battery Replacement
你所需要的
  1. Zeepad 7DRK Battery Replacement, Battery: 步骤 1 中的图像 1,2 Zeepad 7DRK Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Begin the process by prying off the back of the Zeepad using the opening tool.
    • Start by edging the corner of the opening tool into the edge of the device and work your way from there until the back cover is removed.
  2. Zeepad 7DRK Battery Replacement: 步骤 2 中的图像 1,1
    • Once the back casing has been removed, identify the location of the battery inside the device, marked with the red circle.
  3. Zeepad 7DRK Battery Replacement: 步骤 3 中的图像 1,3 Zeepad 7DRK Battery Replacement: 步骤 3 中的图像 2,3 Zeepad 7DRK Battery Replacement: 步骤 3 中的图像 3,3
    • Identify the pieces of tape holding the battery to the back of the screen, and peel them off to remove them.
  4. Zeepad 7DRK Battery Replacement: 步骤 4 中的图像 1,3 Zeepad 7DRK Battery Replacement: 步骤 4 中的图像 2,3 Zeepad 7DRK Battery Replacement: 步骤 4 中的图像 3,3
    • Locate the connection between the battery and motherboard, and disconnect it by pulling the two apart.
  5. Zeepad 7DRK Battery Replacement: 步骤 5 中的图像 1,3 Zeepad 7DRK Battery Replacement: 步骤 5 中的图像 2,3 Zeepad 7DRK Battery Replacement: 步骤 5 中的图像 3,3
    • To finally finish removing the battery, the two wires connecting to it must be separated.
    • Peel back the tape covering the origin of the wires.
    • Finally, remove the two metal connectors attached to the green piece from the battery with a tug.
    • The battery has now been successfully removed.
结论
Alexandra Souza
于10/20/16注册
222 声望
创作了2篇指南
团队
UMass Dartmouth, Team 6-8, Martin Fall 2016 UMass Dartmouth, Team 6-8, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S6G8
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 761
