跳转到主内容
Zebra ZP 505 Peel and Present System Replacement
你所需要的
  1. Zebra ZP 505 Peel and Present System Replacement, Peel and Present System: 步骤 1 中的图像 1,2 Zebra ZP 505 Peel and Present System Replacement, Peel and Present System: 步骤 1 中的图像 2,2
    • Orient the printer so that the bottom is facing up.
    • Remove the three P1 9mm screws located on the bottom of the printer and remove the lower unit.
  2. Zebra ZP 505 Peel and Present System Replacement: 步骤 2 中的图像 1,2 Zebra ZP 505 Peel and Present System Replacement: 步骤 2 中的图像 2,2
    • Remove the P0 9mm screw.
    • Proceed to remove the cover.
  3. Zebra ZP 505 Peel and Present System Replacement: 步骤 3 中的图像 1,1
    • Disconnect the harness.
    • Thread the harness through the hole on the right hand side.
  4. Zebra ZP 505 Peel and Present System Replacement: 步骤 4 中的图像 1,1
    • Remove the peel and present system by utilizing a metal spudger.
  5. Zebra ZP 505 Peel and Present System Replacement: 步骤 5 中的图像 1,1
    • Remove the peel and present system.
结论
Brian Jagger
于09/27/17注册
316 声望
创作了3篇指南
团队
Cal Poly, Team S8-G2, Banghart Fall 2017 Cal Poly, Team S8-G2, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S8G2
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 986
