跳转到主内容
Zebco 33 The Spool and the Line Replacement
你所需要的
  1. Zebco 33 The Spool and the Line Replacement, The Spool and the Line: 步骤 1 中的图像 1,1
    • Remove the old line remaining on the Zebco 33 by pressing down on the large spool release button on the back of the reel. Pull the old line off the reel.
  2. Zebco 33 The Spool and the Line Replacement: 步骤 2 中的图像 1,1
    • Open the front spool cover of the Zebco 33 reel by turning it to the left and pulling it straight off.
  3. Zebco 33 The Spool and the Line Replacement: 步骤 3 中的图像 1,1
    • Cut the line free from the Zebco 33 spool. Pull the line through the front spool cover and then through the line.
  4. Zebco 33 The Spool and the Line Replacement: 步骤 4 中的图像 1,1
    • Thread the line through the hole in the center of the front spool cover and then around the spool of the reel.
  5. Zebco 33 The Spool and the Line Replacement: 步骤 5 中的图像 1,1
    • Attach the line to the spool of the Zebco 33 with a knot. Double the knot and then pull the knot down tightly against the spool of the reel. Clip the extra line from the knot.
  6. Zebco 33 The Spool and the Line Replacement: 步骤 6 中的图像 1,1
    • Put the front spool cover back on the reel. Hold the line a few inches in front of the spool and apply slight tension to the line. Wind the line onto the reel by turning the handle of the reel.
结论
另外一个人完成了本指南。
2条评论
I have a 33K that I cant get the front cover off. I need advice please jamkauf48@gmail.com
James Kaufman - 回复
Instructions need to be much clearer and pictures must be clear.
Functions are difficult to understand……..
Wayne Yeager - 回复
添加评论
浏览统计数据:
过去 24 小时: 16
过去 7 天: 125
过去 30 天: 615
总计 56,377
