简介
我的 Zanussi (扎努西)洗衣机有一段时间工作不是那么正常。
然后停止旋转和排空,那么根本就不会通过这些程序。
我清理了所有的管道,检查了电机电刷,上油和检查了电机,没有用。
我发现了接下来的这个方法,并保持完美的工作 -
下一次它变得不可思议先试试吧!
Seán
将表盘关闭。
按住开始按钮(带绿色箭头的按钮)和按钮左边的按钮。
在按住的同时,顺时针旋转程序旋钮1'点击'(至90度的温度)。
现在顺时针转动旋钮9次。
请注意显示的错误代码。
继续顺时针转动拨盘,直到关闭,然后转到任何程序,然后退出。
按照本指南相反步骤来重新组装设备。
按照本指南相反步骤来重新组装设备。
24等其他人完成本指南。
由衷感谢以下译者:
100%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
58条评论
Fantastic. I had spent a very frustrating hour trying to sort the problem with my machine. Last resort before buying a new one was to trawl the internet. Came across this solution and, bingo, it worked. So pleased and grateful for the info, saved me a bundle!!
It shows me E72,what i have to do?
I tried this although in my machine the 'extra rinse' button is not there but a half load button instead. I never the less used this button & what happened is as described. I only needed to turn the dial 8 turns, 40 degrees light wash & the unit made a few cycles then spun at top speed. So far ok. Unfortunately this seems to have upset the programmer which does not follow it's normal pattern of events.
Don't know what to do now except, maybe experiment to get a full wash the go through the procedure again to spin.
Any further help would be appreciated,
Vic Funnell
Regarding your programmer not displaying the normal wash cycles did you manage to resolve this.
This has just worked for me. Thanku very much
