跳转到主内容
ZTE ZMax Pro Power Button Replacement
你所需要的
  1. ZTE ZMax Pro Power Button Replacement, Back Panel Assembly: 步骤 1 中的图像 1,1
    • Flip the phone over so that the back panel of the phone is facing up.
    • Wedge the plastic opening tool between the black outer panel and the silver side panel.
    • Push down on the plastic opening tool to separate the back panel from the rest of the phone.
    • Continue to do this around all sides of the phone until the back panel has popped all the way off.
    • Removing the back panel may make loud popping noises which is normal.
  2. ZTE ZMax Pro Power Button Replacement: 步骤 2 中的图像 1,1
    • Using your fingers, slide the SIM card all the way out of the phone.
  3. ZTE ZMax Pro Power Button Replacement: 步骤 3 中的图像 1,2 ZTE ZMax Pro Power Button Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the yellow Kapton tape by using the tweezers to peel it up and away from the device.
  4. ZTE ZMax Pro Power Button Replacement: 步骤 4 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the two 3.0 mm screws located near the top of the phone, next to the rear camera.
  5. ZTE ZMax Pro Power Button Replacement: 步骤 5 中的图像 1,1
    • Remove the fingerprint sensor flex cable, using the plastic opening tool to lift it out.
  6. ZTE ZMax Pro Power Button Replacement: 步骤 6 中的图像 1,2 ZTE ZMax Pro Power Button Replacement: 步骤 6 中的图像 2,2
    • Using the tweezers, peel back the yellow Kapton tape located on the right side of the phone.
  7. ZTE ZMax Pro Power Button Replacement: 步骤 7 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the 15, 3.0 mm rear panel screws located around the perimeter of the phone.
  8. ZTE ZMax Pro Power Button Replacement: 步骤 8 中的图像 1,1
    • Flip the phone over so that the screen is facing up.
    • Wedge the plastic opening tool between the screen and the rear panel.
    • Push up on the opening tool to separate the panel from the phone.
    • Continue to do this around the entire phone until the rear panel is no longer connected to the device.
    • The rear case and screen are fastened tightly to each other. It might help to use the picks as wedges to keep the case and screen separated as you run the opening tool along the edges.
  9. ZTE ZMax Pro Power Button Replacement, Power Button: 步骤 9 中的图像 1,1
    • Use the plastic opening tool to remove the lower left connector on the motherboard.
  10. ZTE ZMax Pro Power Button Replacement: 步骤 10 中的图像 1,1
    在这个步骤中使用的工具:
    • Use tweezers to pull back on the power button.
  11. ZTE ZMax Pro Power Button Replacement: 步骤 11 中的图像 1,1
    • Use the tweezers to pull back on the volume buttons.
  12. ZTE ZMax Pro Power Button Replacement: 步骤 12 中的图像 1,1
    • Use the tweezers to pull back on the cable connecting the power and volume button until it is removed.
结论
6等其他人完成本指南。
Nicholas Leacox
于04/18/18注册
1,739 声望
创作了7篇指南
团队
Cal Poly, Team S17-G3, Livingston Spring 2018 Cal Poly, Team S17-G3, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S17G3
4 名成员
创作了16篇指南
1指南评论
Hpw much to repair ()
Manny Carreon - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 27
总计 3,127
