跳转到主内容
简介
A guide on the replacement of the volume buttons on a ZTE ZMAX Z970 smartphone.
  1. ZTE ZMAX Z970 Volume Button Replacement, Battery: 步骤 1 中的图像 1,2 ZTE ZMAX Z970 Volume Button Replacement, Battery: 步骤 1 中的图像 2,2
    • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
    • Pull out the trays.
  2. ZTE ZMAX Z970 Volume Button Replacement: 步骤 2 中的图像 1,2 ZTE ZMAX Z970 Volume Button Replacement: 步骤 2 中的图像 2,2
    • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
    • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
  3. ZTE ZMAX Z970 Volume Button Replacement: 步骤 3 中的图像 1,3 ZTE ZMAX Z970 Volume Button Replacement: 步骤 3 中的图像 2,3 ZTE ZMAX Z970 Volume Button Replacement: 步骤 3 中的图像 3,3
    • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
  4. ZTE ZMAX Z970 Volume Button Replacement: 步骤 4 中的图像 1,2 ZTE ZMAX Z970 Volume Button Replacement: 步骤 4 中的图像 2,2
    • Remove the mid frame with the plastic opening tool.
  5. ZTE ZMAX Z970 Volume Button Replacement: 步骤 5 中的图像 1,2 ZTE ZMAX Z970 Volume Button Replacement: 步骤 5 中的图像 2,2
    • Disconnect the battery from the motherboard.
  6. ZTE ZMAX Z970 Volume Button Replacement: 步骤 6 中的图像 1,2 ZTE ZMAX Z970 Volume Button Replacement: 步骤 6 中的图像 2,2
    • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
    • Once free from the glue, remove from device.
    • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
  7. ZTE ZMAX Z970 Volume Button Replacement, Volume Button: 步骤 7 中的图像 1,2 ZTE ZMAX Z970 Volume Button Replacement, Volume Button: 步骤 7 中的图像 2,2
    • Peel off circuit board carefully.
    • The new part will need to be soldered onto the motherboard.
结论
Burak Cengiz
于2018年02月15日注册
480 声望
创作了4篇指南
团队
USF Tampa, Team S17-G3, Boczar Spring 2018 USF Tampa, Team S17-G3, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S17G3
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 271
