跳转到主内容
ZTE ZMAX Z970 Battery Replacement
你所需要的
  1. ZTE ZMAX Z970  Battery Replacement, Battery: 步骤 1 中的图像 1,2 ZTE ZMAX Z970  Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
    • Pull out the trays.
  2. ZTE ZMAX Z970  Battery Replacement: 步骤 2 中的图像 1,2 ZTE ZMAX Z970  Battery Replacement: 步骤 2 中的图像 2,2
    • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
    • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
  3. ZTE ZMAX Z970  Battery Replacement: 步骤 3 中的图像 1,3 ZTE ZMAX Z970  Battery Replacement: 步骤 3 中的图像 2,3 ZTE ZMAX Z970  Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
  4. ZTE ZMAX Z970  Battery Replacement: 步骤 4 中的图像 1,2 ZTE ZMAX Z970  Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the mid frame with the plastic opening tool.
  5. ZTE ZMAX Z970  Battery Replacement: 步骤 5 中的图像 1,2 ZTE ZMAX Z970  Battery Replacement: 步骤 5 中的图像 2,2
    • Disconnect the battery from the motherboard.
  6. ZTE ZMAX Z970  Battery Replacement: 步骤 6 中的图像 1,2 ZTE ZMAX Z970  Battery Replacement: 步骤 6 中的图像 2,2
    • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
    • Once free from the glue, remove from device.
    • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
结论
3等其他人完成本指南。
Burak Cengiz
于02/15/18注册
480 声望
创作了4篇指南
团队
USF Tampa, Team S17-G3, Boczar Spring 2018 USF Tampa, Team S17-G3, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S17G3
3 名成员
创作了10篇指南
一条评论
Although I haven’t yet embarked on this task, I feel more confident in doing so successfully. I have watched the Youtube videos on this and none of them showed such things as the number and placement of the screws. They did give some idea as to the difficulty of it however.
Please continue to produce more of these instructional blurbs.
aikidoronin - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 1,638
