跳转到主内容
ZTE ZFive G LTE Volume and Power Button Replacement
你所需要的
  1. ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: 步骤 1 中的图像 1,3 ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: 步骤 1 中的图像 2,3 ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: 步骤 1 中的图像 3,3
    • Remove back cover of the device from the crease of the bottom left corner using opening tool or fingernail.
  2. ZTE ZFive G LTE Volume and Power Button Replacement: 步骤 2 中的图像 1,2 ZTE ZFive G LTE Volume and Power Button Replacement: 步骤 2 中的图像 2,2
    • Remove the battery with an opening tool or fingernail.
  3. ZTE ZFive G LTE Volume and Power Button Replacement: 步骤 3 中的图像 1,2 ZTE ZFive G LTE Volume and Power Button Replacement: 步骤 3 中的图像 2,2
    • Unscrew all 16 screws from the mid-frame with a J000 screwdriver.
  4. ZTE ZFive G LTE Volume and Power Button Replacement: 步骤 4 中的图像 1,2 ZTE ZFive G LTE Volume and Power Button Replacement: 步骤 4 中的图像 2,2
    • Being careful with the device, gently pull up the device body tugging from the inside of the device.
    • Be sure to pull away from the device.
  5. ZTE ZFive G LTE Volume and Power Button Replacement: 步骤 5 中的图像 1,2 ZTE ZFive G LTE Volume and Power Button Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Carefully use a pair of bent nose tweezers to pull out the button cover. I should come out easily.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 333
