跳转到主内容
ZTE Z667T Speaker Replacement
你所需要的
  1. ZTE Z667T Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Gently insert your fingernail into the bottom left crevice of the back cover and lift up.
  2. ZTE Z667T Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by inserting your fingernail at the top of the battery and lift up.
  3. ZTE Z667T Speaker Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips #000 screwdriver, remove the five screws located on the back case.
  4. ZTE Z667T Speaker Replacement: 步骤 4 中的图像 1,1
    • Gently pry open the back case using the plastic opening tool.
    • Pry open in multiple locations to avoid damage.
  5. ZTE Z667T Speaker Replacement: 步骤 5 中的图像 1,1
    • Using the plastic opening tool, gently lift the speaker out of the back case.
结论
Michael Lidbetter
于02/12/18注册
139 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 245
