跳转到主内容
ZTE Whirl 2 Speaker Replacement
你所需要的
  1. ZTE Whirl 2 Speaker Replacement, Battery: 步骤 1 中的图像 1,3 ZTE Whirl 2 Speaker Replacement, Battery: 步骤 1 中的图像 2,3 ZTE Whirl 2 Speaker Replacement, Battery: 步骤 1 中的图像 3,3
    • Power off your phone before removing the battery.
    • Pry the cover off the back of the phone using your fingers.
  2. ZTE Whirl 2 Speaker Replacement: 步骤 2 中的图像 1,3 ZTE Whirl 2 Speaker Replacement: 步骤 2 中的图像 2,3 ZTE Whirl 2 Speaker Replacement: 步骤 2 中的图像 3,3
    • Pry the battery from the phone using your fingers.
  3. ZTE Whirl 2 Speaker Replacement, Back Panel: 步骤 3 中的图像 1,3 ZTE Whirl 2 Speaker Replacement, Back Panel: 步骤 3 中的图像 2,3 ZTE Whirl 2 Speaker Replacement, Back Panel: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove four 4 mm screws using a Phillips #00 screwdriver.
    • Use a tweezers to remove the lock sticker from the bottom right screw. Remove the 4 mm screw using a Phillips #00 screwdriver.
  4. ZTE Whirl 2 Speaker Replacement: 步骤 4 中的图像 1,3 ZTE Whirl 2 Speaker Replacement: 步骤 4 中的图像 2,3 ZTE Whirl 2 Speaker Replacement: 步骤 4 中的图像 3,3
    • Insert an opening pick between the midframe and the digitizer.
    • Move the pick around the midframe to detach the midframe from the digitizer.
    • The lock button and volume buttons may fall out during this process.
  5. ZTE Whirl 2 Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the midframe from the digitizer.
  6. ZTE Whirl 2 Speaker Replacement, Speaker: 步骤 6 中的图像 1,2 ZTE Whirl 2 Speaker Replacement, Speaker: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to remove the lock button and volume stickers from the phone.
    • The volume buttons peel off much like a sticker.
  7. ZTE Whirl 2 Speaker Replacement: 步骤 7 中的图像 1,1
    • Use a tweezers to lift the lock from the ZIF connector above the camera. Pull the ribbon from the connector.
    • The ribbon is connected by a lock. Flip the lock up to unlatch the ribbon with a set of tweezers.
  8. ZTE Whirl 2 Speaker Replacement: 步骤 8 中的图像 1,2 ZTE Whirl 2 Speaker Replacement: 步骤 8 中的图像 2,2
    • Use a tweezers to lift the lock from the ZIF connector. Pull the ribbon from the connector.
    • Like the camera ribbon, it has a latch that you need to flip to unlock.
  9. ZTE Whirl 2 Speaker Replacement: 步骤 9 中的图像 1,1
    • Pull the speaker from the phone by using a pair of tweezers.
    • The speaker has a sticky like back, it peels easiest with a tweezers.
结论
Alana Rucks
于02/04/20注册
461 声望
创作了4篇指南
团队
UW Stout, Team S1-G1, Schneider-Bateman Spring 2020 UW Stout, Team S1-G1, Schneider-Bateman Spring 2020 的会员
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G1
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 158
