跳转到主内容
ZTE Tempo X Charging/Aux Board Replacement
你所需要的
  1. ZTE Tempo X Charging/Aux Board Replacement, Back Cover: 步骤 1 中的图像 1,2 ZTE Tempo X Charging/Aux Board Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove back cover using the divot provided.
  2. ZTE Tempo X Charging/Aux Board Replacement, Battery: 步骤 2 中的图像 1,2 ZTE Tempo X Charging/Aux Board Replacement, Battery: 步骤 2 中的图像 2,2
    • Find the divot near the bottom of the battery and remove the battery from the device.
  3. ZTE Tempo X Charging/Aux Board Replacement, Charging/Aux Board: 步骤 3 中的图像 1,2 ZTE Tempo X Charging/Aux Board Replacement, Charging/Aux Board: 步骤 3 中的图像 2,2
    • Remove the sixteen 3mm screws using the Phillips #000 screwdriver.
  4. ZTE Tempo X Charging/Aux Board Replacement: 步骤 4 中的图像 1,2 ZTE Tempo X Charging/Aux Board Replacement: 步骤 4 中的图像 2,2
    • Take off the second back cover, lifting from the bottom of the device to the top.
  5. ZTE Tempo X Charging/Aux Board Replacement: 步骤 5 中的图像 1,3 ZTE Tempo X Charging/Aux Board Replacement: 步骤 5 中的图像 2,3 ZTE Tempo X Charging/Aux Board Replacement: 步骤 5 中的图像 3,3
    • Using a spudger, unclip the board from the phone at the places highlighted.
  6. ZTE Tempo X Charging/Aux Board Replacement: 步骤 6 中的图像 1,3 ZTE Tempo X Charging/Aux Board Replacement: 步骤 6 中的图像 2,3 ZTE Tempo X Charging/Aux Board Replacement: 步骤 6 中的图像 3,3
    • Use the spudger to remove the board from the phone.
    • The board is held by glue so there will be resistance when detaching it from the phone.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 229
