跳转到主内容
ZTE Tempo Rear Camera Replacement
你所需要的
  1. ZTE Tempo Rear Camera Replacement, Rear Camera: 步骤 1 中的图像 1,2 ZTE Tempo Rear Camera Replacement, Rear Camera: 步骤 1 中的图像 2,2
    • Pry open the back case to get to the back cover.
    • Remove eight 5mm screws with a PH0 screw.
    • Pry open the back cover with a plastic opening tool.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
    • Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
  2. ZTE Tempo Rear Camera Replacement: 步骤 2 中的图像 1,2 ZTE Tempo Rear Camera Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
  3. ZTE Tempo Rear Camera Replacement: 步骤 3 中的图像 1,2 ZTE Tempo Rear Camera Replacement: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the rear camera ribbon cable.
    • Lift the rear camera out of the phone.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 163
