跳转到主内容
ZTE Telstra T95 SIM Card Replacement
  1. ZTE Telstra T95 SIM Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
    • You may also use your finger nail if you do not have a plastic opening tool at hand.
  2. ZTE Telstra T95 SIM Card Replacement: 步骤 2 中的图像 1,1
    • Using a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
    • The battery snaps out of place and you can remove it using your fingers.
    • When you are ready to insert a battery make sure the three copper teeth on the phone are aligned with the 3 copper dents on the battery.
  3. ZTE Telstra T95 SIM Card Replacement, SIM Card: 步骤 3 中的图像 1,1
  4. ZTE Telstra T95 SIM Card Replacement: 步骤 4 中的图像 1,1
    • Using your a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
  5. ZTE Telstra T95 SIM Card Replacement: 步骤 5 中的图像 1,2 ZTE Telstra T95 SIM Card Replacement: 步骤 5 中的图像 2,2
    • Remove the SIM card by placing your index finger over it and sliding it out.
    • When you are ready to re-insert the SIM card make sure the pink side facing up.
结论
2等其他人完成本指南。
Jeesenia Rios
于10/25/14注册
300 声望
创作了2篇指南
团队
Gateway, Team 1-1, Johnson Fall 2014 Gateway, Team 1-1, Johnson Fall 2014 的会员
GCC-JOHNSON-F14S1G1
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 801
