简介
You will be able to replace the keypad on your ZTE Telstra T95. No background information required.
你所需要的
Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
Unscrew the phone casing using a small screw driver. Remove the four screws on each corner on the back of the phone.
另外一个人完成了本指南。
