简介
In this guide you will learn how to replace the headphone jack on your ZTE Telstra T95. Soldering background required.
你所需要的
Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
Unscrew the phone casing using a small screw driver. Remove the four screws on each corner on the back of the phone.
Remove the back casing by taking the motherboard and back casing and pulling them apart.
The headphone jack is a square piece at the bottom center of the phone that is sticking out.
If it is loose simply remove it.
If it is still attached you must remove the headphone jack using the heat pen on your soldering station on top of the headphone jack until it becomes loose.
Gently remove the headphone jack using tweezers.
另外一个人完成了本指南。
