跳转到主内容
ZTE Telstra T95 Battery Replacement
你所需要的
  1. ZTE Telstra T95 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
    • You may also use your finger nail if you do not have a plastic opening tool at hand.
  2. ZTE Telstra T95 Battery Replacement: 步骤 2 中的图像 1,1
    • Using a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
    • The battery snaps out of place and you can remove it using your fingers.
    • When you are ready to insert a battery make sure the three copper teeth on the phone are aligned with the 3 copper dents on the battery.
结论
另外一个人完成了本指南。
Jeesenia Rios
于10/25/14注册
300 声望
创作了2篇指南
团队
Gateway, Team 1-1, Johnson Fall 2014 Gateway, Team 1-1, Johnson Fall 2014 的会员
GCC-JOHNSON-F14S1G1
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 330
