跳转到主内容
ZTE Speed Headphone Jack Replacement
你所需要的
  1. ZTE Speed Headphone Jack Replacement, Motherboard: 步骤 1 中的图像 1,2 ZTE Speed Headphone Jack Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Pull off back cover at bottom right corner.
  2. ZTE Speed Headphone Jack Replacement: 步骤 2 中的图像 1,2 ZTE Speed Headphone Jack Replacement: 步骤 2 中的图像 2,2
    • Remove the seven 3.175mm Phillips head screws from the inner back located at the top, upper-middle-right, middle-right, lower-right, and bottom.
  3. ZTE Speed Headphone Jack Replacement: 步骤 3 中的图像 1,2 ZTE Speed Headphone Jack Replacement: 步骤 3 中的图像 2,2
    • With the plastic opening tool the spudger, gently pry off the inner back.
    • Be careful not to pry it off too hard, as it is just a plastic covering.
  4. ZTE Speed Headphone Jack Replacement: 步骤 4 中的图像 1,1
    • Remove the one 2.381mm Phillips head screw from the motherboard located in the upper-middle part of the phone next to the bottom left corner of the back camera.
  5. ZTE Speed Headphone Jack Replacement: 步骤 5 中的图像 1,3 ZTE Speed Headphone Jack Replacement: 步骤 5 中的图像 2,3 ZTE Speed Headphone Jack Replacement: 步骤 5 中的图像 3,3
    • Using the spudger, gently pry up all ZIF connectors
    • ZIF connectors have a tiny tab that needs to be flipped up in order to safely remove the cable
    • Using same spudger, gently pry up the orange flat top connector
  6. ZTE Speed Headphone Jack Replacement: 步骤 6 中的图像 1,2 ZTE Speed Headphone Jack Replacement: 步骤 6 中的图像 2,2
    • Carefully take off motherboard.
  7. ZTE Speed Headphone Jack Replacement, Headphone Jack: 步骤 7 中的图像 1,2 ZTE Speed Headphone Jack Replacement, Headphone Jack: 步骤 7 中的图像 2,2
    • Flip over motherboard to locate headphone jack circuit.
结论
Garrett Barry
于03/04/16注册
722 声望
创作了5篇指南
团队
UMass Dartmouth, Team 6-3, Bhusal Spring 2016 UMass Dartmouth, Team 6-3, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S6G3
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 246
