简介
Consider replacing the front camera of your ZTE Maven 3 for a few key reasons. First, if the current camera consistently produces blurry or distorted images, a replacement could significantly enhance the quality of your selfies and video calls.
Additionally, a malfunctioning or nonfunctional front camera might disrupt your ability to take photos or engage in video chats, necessitating a replacement to restore normal functionality.
Moreover, upgrading to a new front camera could offer improved resolution, better performance in low-light conditions, or additional features, ultimately elevating your overall photography experience on the device.
你所需要的
Locate the small indent on the back right bottom corner of the phone.
Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
Locate the battery in the middle of the back of the phone.
Push in and up on the battery to remove it from its slot.
Put the battery aside.
Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
Detach the ribbon cable connecting the camera in the top middle left of the phone.
Use blunt tweezers to pull the camera off and put it aside.
