跳转到主内容
ZTE Lever Front Camera Replacement
你所需要的
  1. ZTE Lever Front Camera Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Front Camera Replacement: 步骤 2 中的图像 1,2 ZTE Lever Front Camera Replacement: 步骤 2 中的图像 2,2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Front Camera Replacement: 步骤 3 中的图像 1,2 ZTE Lever Front Camera Replacement: 步骤 3 中的图像 2,2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Front Camera Replacement: 步骤 4 中的图像 1,2 ZTE Lever Front Camera Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Front Camera Replacement: 步骤 5 中的图像 1,1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Front Camera Replacement, Front Camera: 步骤 6 中的图像 1,2 ZTE Lever Front Camera Replacement, Front Camera: 步骤 6 中的图像 2,2
    • Unscrew the three 1.6mm Philllips #0 screws on the plastic cover that are near the top edge of the phone by the camera.
    • Pry off the plastic cover using the iFixit opening tool.
  7. ZTE Lever Front Camera Replacement: 步骤 7 中的图像 1,2 ZTE Lever Front Camera Replacement: 步骤 7 中的图像 2,2
    • Unplug the front-facing camera press fit connector cable using the iFixit opening tool.
    • Remove the camera from the motherboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 125
