跳转到主内容
ZTE Jasper LTE Speaker Replacement
你所需要的
  1. ZTE Jasper LTE Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Insert the spudger into the bottom left corner of the phone.
    • Use the spudger to loosen the back cover.
  2. ZTE Jasper LTE Speaker Replacement: 步骤 2 中的图像 1,1
    • Insert the black spudger near the bottom left of the battery. There will be an opening to easily to remove the battery.
    • Continuing to use tool, prop up the battery and remove it.
  3. ZTE Jasper LTE Speaker Replacement, Camera: 步骤 3 中的图像 1,2 ZTE Jasper LTE Speaker Replacement, Camera: 步骤 3 中的图像 2,2
    • Remove nine 0.8mm Phillips #00 screws.
  4. ZTE Jasper LTE Speaker Replacement: 步骤 4 中的图像 1,2 ZTE Jasper LTE Speaker Replacement: 步骤 4 中的图像 2,2
    • Remove the back cover by pulling upwards.
    • Removing the back cover may take a bit of force.
  5. ZTE Jasper LTE Speaker Replacement: 步骤 5 中的图像 1,3 ZTE Jasper LTE Speaker Replacement: 步骤 5 中的图像 2,3 ZTE Jasper LTE Speaker Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Disconnect the gold component attached to the camera by pulling upwards using the tweezers.
    • Remove the camera using the tweezers by gripping tightly around the camera and pulling upwards.
    • Camera is attached to the motherboard with adhesive. As such, you may need to use light force to remove the camera.
  6. ZTE Jasper LTE Speaker Replacement, Speaker: 步骤 6 中的图像 1,2 ZTE Jasper LTE Speaker Replacement, Speaker: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the speaker using the tweezers by gripping each side and pulling upwards.
    • Speaker is attached to the back case with adhesive. As such, you may need to use light force to remove the speaker.
结论
Anthony Sou
于04/22/19注册
391 声望
创作了4篇指南
团队
UW Tacoma, Team S1-G1, Cardinal Spring 2019 UW Tacoma, Team S1-G1, Cardinal Spring 2019 的会员
UWT-CARDINAL-S19S1G1
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 114
