跳转到主内容
ZTE Grand X Max Plus Battery Replacement
你所需要的
  1. ZTE Grand X Max Plus Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Make sure you turn off your phone before starting.
    • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
    • You can also use a hair dryer or a heating gun for this step.
  2. ZTE Grand X Max Plus Battery Replacement: 步骤 2 中的图像 1,2 ZTE Grand X Max Plus Battery Replacement: 步骤 2 中的图像 2,2
    • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
    • Don't apply too much pressure because the cover can crack easily.
    • To avoid that your cover cracks, you can add tape to back cover.
    • You can use a suction cup to help remove the battery.
  3. ZTE Grand X Max Plus Battery Replacement: 步骤 3 中的图像 1,2 ZTE Grand X Max Plus Battery Replacement: 步骤 3 中的图像 2,2
    • Carefully remove the cover from the phone.
  4. ZTE Grand X Max Plus Battery Replacement, Battery: 步骤 4 中的图像 1,2 ZTE Grand X Max Plus Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to pry the battery off.
    • The battery will be held down securely by glue, so it'll take quite a bit of sliding underneath to separate it from the compartment.
  5. ZTE Grand X Max Plus Battery Replacement: 步骤 5 中的图像 1,3 ZTE Grand X Max Plus Battery Replacement: 步骤 5 中的图像 2,3 ZTE Grand X Max Plus Battery Replacement: 步骤 5 中的图像 3,3
    • Pull up the piece that is connected to the motherboard. You can pull it using your nails.
  6. ZTE Grand X Max Plus Battery Replacement: 步骤 6 中的图像 1,2 ZTE Grand X Max Plus Battery Replacement: 步骤 6 中的图像 2,2
    • Remove the battery.
结论
3等其他人完成本指南。
Jordano Baer
于10/02/17注册
689 声望
创作了5篇指南
团队
USF Tampa, Team S9-G4, Remmell Fall 2017 USF Tampa, Team S9-G4, Remmell Fall 2017 的会员
USFT-REMMELL-F17S9G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 2,988
