跳转到主内容
ZTE Compel Speaker Replacement
你所需要的
  1. ZTE Compel Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
  2. ZTE Compel Speaker Replacement: 步骤 2 中的图像 1,1
    • In the bottom right corner of the device, use your fingernail to remove the back cover of the phone by lifting up and holding the device with your other hand.
  3. ZTE Compel Speaker Replacement: 步骤 3 中的图像 1,1
    • In the top-right area of the battery, use your fingernail to lift the battery out of the phone.
    • If your battery is corroded, take all necessary precautions, such as, gloves and protective eyewear.
  4. ZTE Compel Speaker Replacement, Speaker: 步骤 4 中的图像 1,2 ZTE Compel Speaker Replacement, Speaker: 步骤 4 中的图像 2,2
    • Remove the 9 screws that measure 4 mm Phillips. Use your PH000 screwdriver attachment.
    • Use your iFixit Magnetic Project Mat to hold your removed screws while working on your ZTE Compel
  5. ZTE Compel Speaker Replacement: 步骤 5 中的图像 1,3 ZTE Compel Speaker Replacement: 步骤 5 中的图像 2,3 ZTE Compel Speaker Replacement: 步骤 5 中的图像 3,3
    • Insert the flat end of your black plastic spudger into the crease and work it around the entire circumference of the phone until the front and back are separated.
  6. ZTE Compel Speaker Replacement: 步骤 6 中的图像 1,1
    • The speaker is located in the top-left corner of the back plate. Using your tweezers, grip the sides of the speaker and pull it out.
    • Be cautious pulling the speaker out as it might move while pulling it due to adhesive wearing away.
结论
Tayler McCleese
于09/06/18注册
246 声望
创作了2篇指南
团队
Ohio State, Team S1-G4, Whitney Fall 2018 Ohio State, Team S1-G4, Whitney Fall 2018 的会员
OSU-WHITNEY-F18S1G4
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 140
