简介
The ZTE Compel features an LCD Touch Screen. You may need to replace the screen if it no longer responds to touch commands, is discolored, or if you cracked your screen. Please take all necessary precautions, such as protective gloves and eye wear, if dealing with battery corrosion.
你所需要的
Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
Use your tweezers to remove the black electrical tape covering connectors to the motherboard.
Use your tweezers to flip the brown clip up, and pull the ribbon connectors out of the connections.
The front screen is separated from the motherboard, so you may replace the front LCD touch screen now.
另外一个人完成了本指南。
