简介
The volume and power buttons are connected to the same ribbon cable. If just one of the three buttons fails, you will have to replace all three in order to fix it.
你所需要的
Turn the device on it side with the buttons away from you.
Using the SIM Card Eject Tool, insert the narrow end into the ejection hole.
Press firmly into the hole until the SIM card tray pops out far enough to grab with your fingers.
Remove the one T2 screw from the side of the phone near where the SIM card tray was.
5等其他人完成本指南。
3条评论
can you do a videomplz
I need help. When I plug the charger in it would turn on but since the power button was broken I had to buy a new one and today I had received it. Now I did everything correctly however, on step 14 I didn't use tweezers since I didn't have any to remove the ribbon and the ribbon didn't get affected but on top where the ribbon goes in at broke. It should still turn on. So I put everything back and put the charger in and it charges but it doesn't show that it's charging now. And whenever I hold the power button the light twitches but the phone doesn't turn on or even show the percent of the battery which never did that until now. Did I do something wrong? Current trying to redo everything.
I can’t believe I was able to fix this thing! Amazing. Ordered the button, took it apart with my kit and rebuilt it. Not to mention I took apart my Mac ProBook and fixed that too!! Apple Store - It’s hopeless, your data is gone forever. Get a new machine. Best Buy - It’s hopeless, your data is gone forever. Get a new machine.
Nope!
