跳转到主内容
ZTE Blade X Max Midframe Replacement
你所需要的
  1. ZTE Blade X Max Midframe Replacement, Back Cover: 步骤 1 中的图像 1,2 ZTE Blade X Max Midframe Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Use the iOpener or heating pad to heat around the edges of the phone to melt the adhesive.
    • It will take about ten minutes for the adhesive to be heated enough to remove the backing.
    • You will have to reheat the iOpener or heating pad a few times.
  2. ZTE Blade X Max Midframe Replacement: 步骤 2 中的图像 1,3 ZTE Blade X Max Midframe Replacement: 步骤 2 中的图像 2,3 ZTE Blade X Max Midframe Replacement: 步骤 2 中的图像 3,3
    • Slide the Jimmy along the under backing and lightly push the plastic up.
    • You will hear a snapping sound as you slide the Jimmy along the backing. This is from the closures releasing. There should be seven total closures on either side of the device, and three on the top and bottom.
  3. ZTE Blade X Max Midframe Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the backing from the phone once the closures are released.
    • If you do not open all of the closures on the backing do not attempt to pry it off.
    • Be careful when opening the back of the phone. The fingerprint scanner is connected by a thin film that will tear if pulled too roughly.
  4. ZTE Blade X Max Midframe Replacement: 步骤 4 中的图像 1,3 ZTE Blade X Max Midframe Replacement: 步骤 4 中的图像 2,3 ZTE Blade X Max Midframe Replacement: 步骤 4 中的图像 3,3
    • Remove the opaque yellow sticker that indicates where the fingerprint scanner is connected to the back of the device.
  5. ZTE Blade X Max Midframe Replacement: 步骤 5 中的图像 1,3 ZTE Blade X Max Midframe Replacement: 步骤 5 中的图像 2,3 ZTE Blade X Max Midframe Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove the two 1mm Phillips #000 screws on the small panel that was underneath the sticker.
    • Use the tweezers to remove the panel.
  6. ZTE Blade X Max Midframe Replacement: 步骤 6 中的图像 1,2 ZTE Blade X Max Midframe Replacement: 步骤 6 中的图像 2,2
    • Use the tweezers to pull at the base of the film to remove the fingerprint scanner.
  7. ZTE Blade X Max Midframe Replacement, Midframe: 步骤 7 中的图像 1,1
    • Remove the SD and SIM cards by pulling out the card tray from the slot on the right side of the device.
  8. ZTE Blade X Max Midframe Replacement: 步骤 8 中的图像 1,3 ZTE Blade X Max Midframe Replacement: 步骤 8 中的图像 2,3 ZTE Blade X Max Midframe Replacement: 步骤 8 中的图像 3,3
    • Remove the sixteen 1mm Phillips #000 screws from the midframe of the phone.
  9. ZTE Blade X Max Midframe Replacement: 步骤 9 中的图像 1,3 ZTE Blade X Max Midframe Replacement: 步骤 9 中的图像 2,3 ZTE Blade X Max Midframe Replacement: 步骤 9 中的图像 3,3
    • Use the Jimmy to remove the midframe from the device.
结论
Kristen Gismondi
于11/12/14注册
99,403 声望
创作了255篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,623篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 283
