跳转到主内容
ZTE Blade Spark Battery Replacement
你所需要的
  1. ZTE Blade Spark Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Apply heat evenly on the back cover using the iOpener to soften the adhesive.
  2. ZTE Blade Spark Battery Replacement: 步骤 2 中的图像 1,2 ZTE Blade Spark Battery Replacement: 步骤 2 中的图像 2,2
    • Carefully remove the back cover using an opening tool.
  3. ZTE Blade Spark Battery Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to carefully remove all fifteen 3.0 mm screws.
    • Gently remove the SIM card tray.
  4. ZTE Blade Spark Battery Replacement: 步骤 4 中的图像 1,1
    • To remove the inner white panel/cover, use a plastic opening tool to loosen from each side.
  5. ZTE Blade Spark Battery Replacement: 步骤 5 中的图像 1,1
    • Set the inner white panel to the side.
  6. ZTE Blade Spark Battery Replacement: 步骤 6 中的图像 1,1
    • After removing the inner white panel you should see a black panel. Use a Phillips #00 screwdriver to remove the six 4.0 mm screws.
  7. ZTE Blade Spark Battery Replacement: 步骤 7 中的图像 1,1
    • Remove the black panel, revealing the battery.
  8. ZTE Blade Spark Battery Replacement: 步骤 8 中的图像 1,1
    • Disconnect the tab connecting the battery to the circuit.
  9. ZTE Blade Spark Battery Replacement: 步骤 9 中的图像 1,1
    • Remove the battery from the device.
  10. ZTE Blade Spark Battery Replacement: 步骤 10 中的图像 1,1
    • Place battery off to the side and retrieve new battery.
结论
Andrew Bliss
于03/27/23注册
181 声望
撰写一个指南
团队
IUPUI, Team 1-3, Harley Spring 2023 IUPUI, Team 1-3, Harley Spring 2023 的会员
IUPUI-HARLEY-S23S1G3
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 230
