跳转到主内容
ZTE Awe Headphone Jack Replacement
你所需要的
  1. ZTE Awe Headphone Jack Replacement, Remove the back cover: 步骤 1 中的图像 1,1
    • Remove the back cover of the phone to expose the phone's mid-frame.
  2. ZTE Awe Headphone Jack Replacement, Remove battery: 步骤 2 中的图像 1,1
    • Pry the battery up and out of the phone.
  3. ZTE Awe Headphone Jack Replacement, Unscrew the phone's mid frame: 步骤 3 中的图像 1,1
    • Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws from the phone's mid frame.
  4. ZTE Awe Headphone Jack Replacement, Separate the mid frame and the digitizer: 步骤 4 中的图像 1,3 ZTE Awe Headphone Jack Replacement, Separate the mid frame and the digitizer: 步骤 4 中的图像 2,3 ZTE Awe Headphone Jack Replacement, Separate the mid frame and the digitizer: 步骤 4 中的图像 3,3
    • Wedge the flat end of the spudger between the mid frame and the digitizer.
  5. ZTE Awe Headphone Jack Replacement, Expose the motherboard: 步骤 5 中的图像 1,2 ZTE Awe Headphone Jack Replacement, Expose the motherboard: 步骤 5 中的图像 2,2
    • Gently pry the mid frame away from the rest of the phone to expose the motherboard.
  6. ZTE Awe Headphone Jack Replacement, Remove the audio jack: 步骤 6 中的图像 1,3 ZTE Awe Headphone Jack Replacement, Remove the audio jack: 步骤 6 中的图像 2,3 ZTE Awe Headphone Jack Replacement, Remove the audio jack: 步骤 6 中的图像 3,3
    • Locate the audio jack at the upper right hand corner of the device.
    • Use the metal spudger to pry the motherboard away from the device.
    • Use the metal spudger to unfasten the audio jack and pull it away from the motherboard.
结论
4等其他人完成本指南。
Jennifer DeMeo
于10/07/14注册
1,035 声望
创作了5篇指南
团队
USF Tampa, Team 1-2, Leahy Fall 2014 USF Tampa, Team 1-2, Leahy Fall 2014 的会员
USFT-LEAHY-F14S1G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 2,504
