跳转到主内容
ZTE Avail 2 Camera Replacement
你所需要的
  1. ZTE Avail 2 Camera Replacement, Battery: 步骤 1 中的图像 1,3 ZTE Avail 2 Camera Replacement, Battery: 步骤 1 中的图像 2,3 ZTE Avail 2 Camera Replacement, Battery: 步骤 1 中的图像 3,3
    • Before disassembling your ZTE Avail 2, be sure it is powered off.
    • Remove the back cover using the notch at the bottom of the device.
    • Pull the back cover from the front panel gently to remove it.
  2. ZTE Avail 2 Camera Replacement: 步骤 2 中的图像 1,2 ZTE Avail 2 Camera Replacement: 步骤 2 中的图像 2,2
    • Remove the battery by the notch in the back plate.
  3. ZTE Avail 2 Camera Replacement, Camera: 步骤 3 中的图像 1,1
    • Using your J00 screwdriver, unscrew each of the 8 Philips head screws from the black plate of the device.
  4. ZTE Avail 2 Camera Replacement: 步骤 4 中的图像 1,2 ZTE Avail 2 Camera Replacement: 步骤 4 中的图像 2,2
    • Using the spudger tool, pull up from underneath the back plate and pop off the piece.
  5. ZTE Avail 2 Camera Replacement: 步骤 5 中的图像 1,2 ZTE Avail 2 Camera Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using the tweezers remove the 4 orange ribbon cables. Do this by lifting their corresponding black connectors and pulling the ribbon out.
  6. ZTE Avail 2 Camera Replacement: 步骤 6 中的图像 1,1
    • On the left side you will see a cellular antenna cable wire. Remove this wire by gently pulling it off.
  7. ZTE Avail 2 Camera Replacement: 步骤 7 中的图像 1,2 ZTE Avail 2 Camera Replacement: 步骤 7 中的图像 2,2
    • Lift up the motherboard, this may require some force because it is held on by adhesive.
    • This will allow you to access the camera and the camera mount.
  8. ZTE Avail 2 Camera Replacement: 步骤 8 中的图像 1,3 ZTE Avail 2 Camera Replacement: 步骤 8 中的图像 2,3 ZTE Avail 2 Camera Replacement: 步骤 8 中的图像 3,3
    • Where you can see the front of the camera lightly push on the camera to remove the camera from its holding. The camera will come through the back.
    • Once out of the holding remove the clip holding it to the underside of the motherboard. Now the camera is removed.
    • Once the old camera is removed replace it with the new camera to complete the repair.
结论
5等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 461
