跳转到主内容
ZTE Avail 2 Battery Replacement
  1. ZTE Avail 2 Battery Replacement, Battery: 步骤 1 中的图像 1,3 ZTE Avail 2 Battery Replacement, Battery: 步骤 1 中的图像 2,3 ZTE Avail 2 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Before disassembling your ZTE Avail 2, be sure it is powered off.
    • Remove the back cover using the notch at the bottom of the device.
    • Pull the back cover from the front panel gently to remove it.
  2. ZTE Avail 2 Battery Replacement: 步骤 2 中的图像 1,2 ZTE Avail 2 Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the battery by the notch in the back plate.
    • Once you have removed the battery replace it with the new one.
    • Carefully insert the new battery with the connectors aligned correctly.
    • Gently push down on the battery until it clicks into place.
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 517
